arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Join Table: Dataset tablexxx does not exist or is not supported
import pyodbc, arcgisscripting,arcpy arcpy = arcgisscripting.create(10.1) arcpy.overwriteoutput = 1 conn = pyodbc.connect(("Driver={Microsoft Access Driver (*.mdb, *.accdb)};" "DBQ=C:\Projects\ProjectDatabases\MIA\PrimaryDatabase.accdb;")) cursor = conn.cursor() InputTransport = "C:\ProjectDatabases\GIS\SIWW_Data_Display.gdb" def TransportationAccess(accdbtable1,gdbfeat1): cursor.execute("delete * from " + accdbtable1) #clear table #join Trans_NodeTypeDetails from geodatabase to Acces_Trans_NodeTypeDetails. Join fields NodeType and Stations arcpy.joinfield_management((InputTransport+"\\"+gdbfeat1),"NodeType",accdbtable1,"NodeType","Stations") TransportationAccess("Access_Trans_NodeTypeDetails", "Nodes")
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Join Table: Dataset Access_Trans_NodeTypeDetails does not exist or is not supported Failed to execute (JoinField).
def TransportationAccess(accdbtable1,gdbfeat1): tblv = "accdbtab" arcpy.MakeTableView_management(accdbtable1, tblv) cursor.execute("delete * from " + accdbtable1) #clear table #join Trans_NodeTypeDetails from geodatabase to Acces_Trans_NodeTypeDetails. Join fields NodeType and Stations arcpy.joinfield_management((InputTransport+"\\"+gdbfeat1),"NodeType",tblv,"NodeType","Stations")
Signed in members can post, follow updates, and more. New here? Register a free account.
