So I am working on a script to automate a process for populating certain fields in several feature classes, but in order to do so I need to determine what kind of geometries these feature classes are. Depending on what kind of feature classes they are, the script runs a certain way. The issue I am having with the script is I am not getting the list of geometries for the feature classes. The feature classes are in sde (not sure if that makes a difference) and I keep getting a list, but not a list of the geometries. Any help would be greatly appreciated.
<SPAN class="keyword token">import</SPAN> arcpy
arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'Database Connections\Storm Water.sde\STORM.GISADMIN.Storm_Network'</SPAN>
fcs <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
descList <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN>
fclist <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> fclist<SPAN class="punctuation token">:</SPAN>
fcs<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> fc <SPAN class="keyword token">in</SPAN> fcs<SPAN class="punctuation token">:</SPAN>
desc <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Describe<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">)</SPAN>
descList<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>desc<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
