So I have a slight predicament for this given scenario. I need to take the last 4 characters from the x coordinate and do the same for the y coordinate. I then need to combine the two and from the combined values, update another field. I have something akin but I keep running into errors. I can get it to list a set of values that I need but trying to get the update cursor to update the records in the field is tricky.
<SPAN class="keyword token">if</SPAN> field<SPAN class="punctuation token">.</SPAN>name <SPAN class="operator token">==</SPAN> <SPAN class="string token">'FACILITY_ID'</SPAN><SPAN class="punctuation token">:</SPAN>
<SPAN class="keyword token">print</SPAN> field<SPAN class="punctuation token">.</SPAN>name
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>SearchCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"FACILITY_ID"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE@X"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SHAPE@Y"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"""FACILITY_ID IS NULL"""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
rowx <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
rowy <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN>row<SPAN class="punctuation token">[</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
x <SPAN class="operator token">=</SPAN> rowx<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN>
y <SPAN class="operator token">=</SPAN> rowy<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">4</SPAN><SPAN class="punctuation token">]</SPAN>
xy <SPAN class="operator token">=</SPAN> x <SPAN class="operator token">+</SPAN> y
<SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>UpdateCursor<SPAN class="punctuation token">(</SPAN>fc<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="string token">"FACILITY_ID"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"""FACILITY_ID IS NULL"""</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
row<SPAN class="punctuation token">.</SPAN>updateRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>xy<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">print</SPAN> <SPAN class="string token">'{} = {}'</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>field<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> xy<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any help on this would be greatly appreciated.
