Is anyone else using python to directly interact with their DBMS?
7754
13
09-10-2014 01:09 PM
ChrisMathers
I use pypodbc to connect and query my SQL servers on occasion and was curious if anyone else was doing this as well. If you are, what module are you using?
ChrisPedrezuela
I use arcpy.ArcSDESQLExecute.
ChrisMathers
I like arcpy.ArcSDESQLExecute but Im not usually looking for spatial data or even geodatabase data when I do this.
CarstenBøcker1
I have used pyodbc for SQL Server and cx_oracle for Oracle. Hovever recently i have turned more and more to AcSDESQLExecute. You don't have to install third party libraries (a problem at many sites) and I also like that the results are returned as lists.
I haven't tested performance, so I don't know if there's an overhead using AcSDESQLExecute compared to the native python libraries.
JamesCrandall
cx_Oracle here.
It's not always SDE data that is needed and non-spatial attribute data can be utilized in functional ways (mapping, joins, raster processing, etc...)
CameronMcCormick
Using cx_Oracle here too.  Great little extension
ZoeZaloudek
I downloaded and installed MySQLdb to access data on our SQL databases.  It was the first thing I tried that worked and I've just been using it ever since.
KevinBrown2
I'm using win32com to instantiate ADODB objects:
<CODE>
from win32com.client import Dispatch
connection = Dispatch('ADODB.Connection')
connection.Open(dsn)
rs = Dispatch('ADODB.RecordSet')
rs = connection.Execute(sql)
</CODE>
ThomasStanley-Jones
I use comtypes to interact with ArcObjects direcly.  I've found it a lot less buggy than arcpy, although I don't do much more than retrieve data from our servers.
def getConnection():
    Creates and returns a connection to the Database
    @return: SdeWorkspace as ISqlWorkspace
    import comtypes.gen.esriSystem as esriSystem
    import comtypes.gen.esriDataSourcesGDB as esriDataSourcesGDB
    import comtypes.gen.esriGeoDatabase as esriGeodatabase
    # Set connection properties for OLE DB connection
    conprop = Snippets.NewObj(esriSystem.PropertySet, esriSystem.IPropertySet)
    conprop.SetProperty("INSTANCE", "sde:sqlserver:?????")
    conprop.SetProperty("DATABASE", "?????")
    conprop.SetProperty("AUTHENTICATION_MODE", "OSA")
    # Create workspace
    SDEWorkspaceFactory = Snippets.NewObj(esriDataSourcesGDB.SdeWorkspaceFactory, esriGeodatabase.IWorkspaceFactory)
    SDEWorkspace = SDEWorkspaceFactory.Open(conprop, 0)
    sqlworkspace = Snippets.CType(SDEWorkspace, esriGeodatabase.ISqlWorkspace)
    return sqlworkspace
ChrisMathers
Wow! Ive never used the comtypes library before. That is really cool. Going to have to add that to the list of things to read up on.
