Importing a view from SQL server into a File Geodatabase using Python
1834
05-07-2019 11:43 AM
Simonde_Verteuil
Hi all,
I've been trying to automate the building of some GIS datasets from the tabular data of a SQL table. My strategy is to import the SQL table into a file geodatabase for processing. I have been messing around with pyodbc  but I cannot quite get it.
If someone can point me in the right direction I would greatly appreciate it.
JakeSkinner
Esri Esteemed Contributor
Hi Simon,
You should be able to use the Table to Table tool.  This works with straight SQL tables.
JakeSkinner
Hi Simon,
