Hi
I am uploading a File geodatabase using the new arcgis.gis API. Because my Portal is 10.4.1, I should be able to publish the contents of the file geodatabase as feature services. I can upload and publish a shape file, but with similar code, uploading a file geodatabase works, but publishing fails.
Here is the code for the uploading the file geodatabase:
from arcgis.gis import *
gis = GIS("http://<myportalserver>/arcgis","<username", "<password>")
data = "C:\\temp\\fgdbtest.zip" # File geodatabase zipped up
item_properties = {}
item_properties ["type"] = "fileGeodatabase" # I need the type definition, otherwise add did not work
fgdbdata = gis.content.add(item_properties, data)# this works, the item is uploaded
fgdbdata.publish() # ERROR:
I get an error that Nonetype has no attribute publish(), so obviously fgdbdata is empty or None. Yet almost the same code does work when uploading a shape file.
Does anyone have an example where a File geodatabase is uploaded as a new item and then the feature classes within published as feature services?
Hugo
