How to pass the iteration result to a parameter
1629
02-04-2021 03:10 AM
Sergey_Grechkin
Hello everybody
I need to pass the list of domains that I have in the database in the script parameter. I didn’t find a suitable option in the data type. I decided to use ListDomains
import arcpy
a=set()
domains = arcpy.da.ListDomains("Database Connections\sde.sde")
for dom in domains:
    a.add(dom.name)
arcpy.GetParameterAsText(0)
but this option doesn't work
how do i pass a list to a script parameter?
Tags (1)
Sergey_Grechkin
David I solved my problem
I wrote in validation
def initializeParameters(self):
"""Refine the properties of a tool's parameters. This method is
called when the tool is opened."""
my=[]
for domain in domains:
my.append(domain.name)
self.params[3].filter.list=sorted(my)
return
Now the parameter displays a list of the required data
import arcpy
fc = arcpy.GetParameterAsText(0)
field = arcpy.GetParameterAsText(1)
domain_1 = arcpy.GetParameterAsText(3)
domain_2 = arcpy.da.ListDomains("Database Connections\sde.sde")
field_1 = arcpy.GetParameterAsText(2)
cursor = arcpy.SearchCursor(fc)
b=set()
a=set()
for domain in domain_2:
if domain.name == domain_1:
for val in domain.codedValues.keys():
b.add(val)
with open(r'R:\{}.txt'.format(field), 'w') as f:
for row in cursor:
k=row.getValue(field)
if k not in b:
a.add(row.getValue(field_1))
if len(a)>0:
f.write ('COLUMN {} IS NOT FILLED BY STANDARD'.format(field)+'\n')
for val in a:
f.write ('{}'.format(val)+'\n')
else:
f.write ('COLUMN {} FILLED BY STANDARD'.format(field)+'\n')
DavidPike
MVP Notable Contributor
Setting script tool parameters—ArcGIS Pro | Documentation
If you look at the multivalue option it should be explained.
Sergey_Grechkin
I don’t understand how to specify for GetParameterAsText() the result of the iteration 😞
I try SetParameterAsText
But SetParameterAsText only works on output and is not displayed in the script window
DavidPike
I'm not completely sure of what you mean, can you not just have the sde connection file as a parameter, then do whatever else within the script?
What's the full script and what do you want to achieve?
Sergey_Grechkin
my=[]
return
import arcpy
b=set()
a=set()
b.add(val)
for row in cursor:
if k not in b:
if len(a)>0:
for val in a:
else:
