How do I install pywin32 for ArcGIS Pro 3.0? It worked for me in 2.x, but in 3.0, the installation fails whether trying it from the Pro user interface (Settings > Package Manager > Add Packages) or in a Python command prompt using conda install or pip install. There seems to be a lot of conflicts in dependency versions. After attempting to install, if I run this code:
from win32com import client
I get:
ImportError: DLL load failed while importing pythoncom: The specified procedure could not be found.
I'm using pywin32 and arcpy to update an APRX and an Excel file and export sheets from Excel to PDF.
