How to do a raster layer summation by loop?
2389
11-11-2017 08:41 PM
RebeccaRicker
Hey folks,
I work with ArcGIS Pro and Python and I need to do a Summation over 31 raster layers. I want to do it by a loop, because I need it more often.
This is what I want to loop:
    arcpy.env.workspace = Folder_Single_Layer_ND_as_0
    Sum_Layer_ND_as_0 = \
    Raster("/offset_0_1.tif") \
    + Raster("/offset_0_2.tif") \
    + Raster("/offset_0_3.tif") \
    + Raster("/offset_0_4.tif") \
    + Raster("/offset_0_5.tif") \
    + Raster("/offset_0_6.tif") \
    + Raster("/offset_0_7.tif") \
    + Raster("/offset_0_8.tif") \
    + Raster("/offset_0_9.tif") \
    + Raster("/offset_0_10.tif") \
    + Raster("/offset_0_11.tif") \
    + Raster("/offset_0_12.tif") \
    + Raster("/offset_0_13.tif") \
    + Raster("/offset_0_14.tif") \
    + Raster("/offset_0_15.tif") \
    + Raster("/offset_0_16.tif") \
    + Raster("/offset_0_17.tif") \
    + Raster("/offset_0_18.tif") \
    + Raster("/offset_0_19.tif") \
    + Raster("/offset_0_20.tif") \
    + Raster("/offset_0_21.tif") \
    + Raster("/offset_0_22.tif") \
    + Raster("/offset_0_23.tif") \
    + Raster("/offset_0_24.tif") \
    + Raster("/offset_0_25.tif") \
    + Raster("/offset_0_26.tif") \
    + Raster("/offset_0_27.tif") \
    + Raster("/offset_0_28.tif") \
    + Raster("/offset_0_29.tif") \
    + Raster("/offset_0_30.tif") \
    + Raster("/offset_0_31.tif") \
    Sum_Layer_ND_as_0.save()
I tried so far...
    # Those are already definite
    # TxWx = "/offset"        # I need this as a Variable.
    # Number_of_Years = 31    # I calculated this from a NetCDF
...this:
    for Number in range(1, int(Number_of_Years))
        Sum_Layer_ND_as_0 += Raster(TxWx + "_0_" + Number + ".tif")
...and this:
    x = 1
    while True:
        Sum_Layer_ND_as_0 += Raster(TxWx + "_0_" + str(x) + ".tif")
        x += int(Number_of_Years)
... and this:
    count = 1
    while count <= int(Number_of_Years):
        Sum_Layer_ND_as_0 += Raster(TXWX + "_0_" + str(count) + ".tif")
        count +=1
Nothing works. I am a very beginner in Python. I would be very grateful if anyone could help me!!!
PS.: If my question is on the wrong position or I am not supposed to ask it here, please tell me.
DanPatterson_Retired
https://community.esri.com/blogs/dan_patterson/2016/08/14/script-formatting to format your code so it is easier to read.
You need to use list rasters and sum the raster datasets using a Local sum
import arcpy
from arcpy import env
env.workspace = "C:/some_folder/a_folder_or_gdb"
arcpy.CheckOutExtension("Spatial")
in_rasters = arcpy.ListRasters("*", "TIF")  # change to suit the raster types
sum_cellstats = CellStatistics_sa(in_rasters, "SUM", "DATA")  # read the help!!
sum_cellstats.save("C:/test/output/sum_o_rama")
which has obviously not been tried but you can examine the various help topics to get the idea of how to work through through the process
import arcpy
RebeccaRicker
Thank you soooooo much again
It worked!
no problem
