How to debug arcpy code in visual studio 2019
3937
8
05-13-2021 02:41 PM
ManishShrivastav
# This script clips all feature classes in a file geodatabase
import arcpy
# Create path variables
sourceWorkspace = r"C:\Users\Lesson2Practice\USA.gdb"
targetWorkspace = r"C:\Users\Lesson2Practice\Iowa.gdb"
clipfeature = r"C:\Users\Lesson2Practice\Iowa.gdb\Iowa"
# Get a list of all feature classes in the USA geodatabase
arcpy.env.workspace = sourceWorkspace
featureClassList = arcpy.ListFeatureClasses()
try:
    # Loop through all USA faeture classes
    for featureClass in featureClassList:
        # Construct the output path
        outClipFeatureClass = f'{targetWorkspace}\Iowa{featureClass}'
        # Perform Clip
        arcpy.Clip_analysis(featureClass,clipfeature,outClipFeatureClass)
        arcpy.AddMessage(f'Wrote clipped file {outClipFeatureClass}.')
        print(f"Wrote clipped file {outClipFeatureClass}.")
except:
    # Report if there was an error
    arcpy.AddError("Could not clip feature classes")
    print("Could not clip feature classses")
    print(arcpy.GetMessages())
I have created a python script file that I am debugging it using visual studio 2019, But as soon as I try to debug, it gives me and Exception on another file (time.py - not sure where it came from as this time.py is not in my project or folder) stating "name 'm' is not defined" (I am attaching a video of the exception). Any help is appreciated.
Thanks
(view in My Videos)
GKmieliauskas
Have you solved issue with "name 'm' is not defined"?
I have the same situation as you
ManishShrivastav
I am still waiting for it.
ChenChen4
I have the same issue. It looks like when I import arcpy in Visual Studio, it loads 'arcpy.time', and it doesn't matter if I use any datetime functions in my code but the debug detects the name error.
I opened the time.py file and in line 267, there is a variable m
try:
del m
except NameError:
pass
I cannot modify this time.py file since it's part of arcpy package. Don't know how to solve this problem.
RobbCampbell
Did anyone Get any help on this? I have the same issue as the rest of you. ChenChen4 is exactly where I got.
BrynR
I'm running into this same message too when adding "import arcpy"
It's annoying but is this actually a problem? I notice you can just click "Continue" on the visual studio toolbar and the rest of my project runs fine.
Also, if I choose to "Debug"-> "Execute Project in Python Interactive" there's no error at all.
GKmieliauskas
When you  wrote "if I choose to "Debug"-> "Execute Project in Python Interactive" there's no error at all.", do you mean running script with $load command?
For me it stops with other things like:
dirname = os.path.dirname(__file__)
BrynR
No, I mean the the option from the Debug menu. Shortcut key Shift+Alt+F5
ACrateau
Did anyone ever solve this?
I am trying to debug a project in VS using the arcgispro-py3 environment.  This error happens when you reference python's datetime.datetime class after the arcpy site package is loaded.
The project works when run in the python interactive window, but throws the same error when using Debug in VS.
