How to add features to referenced feature layer
2274
08-03-2021 07:35 AM
GeoHawaii
Hey All,
I have a referenced feature layer and a hosted feature layer. I need to add or copy the features from the hosted feature layer to the referenced feature layer.
I currently have a script that copies features from one hosted feature layer to another hosted feature layer. If I now use a referenced feature layer I get the following error message: TypeError: unsupported operand type (s) for +: 'FeatureLayer' and 'str'
Is it not possible at the moment?
I use the edit_features function for this
by Anonymous User
Not applicable
Looking at the error, is FeatureLayer an object?  They both need to be strings to be concatenated by the + so make sure both variables are strings.
jcarlson
Sharing your code would help others identify what the problem is. A TypeError may be a very simple fix.
Have you gotten this process to work in the past, or are you still developing it?
- Josh Carlson
Kendall County GIS
by Anonymous User
Not applicable
GeoHawaii
Yes thank you, this was my problem. The referenced feature layer variable was not a str
