Is it pssilble with arcpy?
Or is there an other skript possiblity?
I'm using 10.2, so can't test anything in 10.3, but this doesn't appear to be a property of the Layer object. I'm guessing you're out of luck, at least as far as arcpy goes, which truly isn't meant to do absolutely everything.
Can you please give us a little bit more detail on what you are trying to achieve. I don't quite understand your question.
The same problem as in post Set Layer ID for a layer in ArcMap 10.3
But i want solve it with python.
arcpy mapping
Alphabetical list of arcpy.mapping functions—Help | ArcGIS for Desktop
Alphabetical list of arcpy.mapping classes—Help | ArcGIS for Desktop
amongst other links
I haven't found an arcpy.mapping functions for setting a layer/table-ID.
Even in arcpy.mapping classes i haven't found a method in the class "layer" to set the ID.
Know somebody else more?
Is there a possibility in python with arcobjects?
if the property existed, it could be set, meaning that layers don't have an ID property but it has a readonly ObjectID property
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-functions/table-properties.htm
