i am relatively new to python but I am trying to work on a script that works in conjunction with modelbuilder and so far things were working up to a point. The issue that I am having is I am trying to loop through a list of files, get the filenames, and update a table with the names from the files. Here is the script that I have currently:
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="keyword token">import</SPAN> os
<SPAN class="comment token">#Set Parameters</SPAN>
inFiles <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
inTable <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN>
inField <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN>
outTable <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>SetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Iterate through files in folder, insert rows based on file names, and make table view layer</SPAN>
<SPAN class="keyword token">with</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>da<SPAN class="punctuation token">.</SPAN>InsertCursor<SPAN class="punctuation token">(</SPAN>inTable<SPAN class="punctuation token">,</SPAN> inField<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">as</SPAN> cursor<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#List Files</SPAN>
flist <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>List<SPAN class="punctuation token">(</SPAN>inFiles<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">for</SPAN> f <SPAN class="keyword token">in</SPAN> flist<SPAN class="punctuation token">:</SPAN>
<SPAN class="comment token">#Make table view</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeTableView_management<SPAN class="punctuation token">(</SPAN>inTable<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Get filename(s)</SPAN>
f <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>basename<SPAN class="punctuation token">(</SPAN>flist<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN>rstrip<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>splitext<SPAN class="punctuation token">(</SPAN>flist<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#Insert values and rows in table</SPAN>
cursor<SPAN class="punctuation token">.</SPAN>insertRow<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>f<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">del</SPAN> cursor
<SPAN class="comment token">#Add Message</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"This row {0} was added."</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>f<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Any help on this would be greatly appreciated.
