I want to automate adding a domain to a field. I need to do this a bunch of times with multiple feature classes that have multiple subtypes. Is there a wildcard I can use for the subtype parameter to grab all of them? Another method I'm not thinking of?
Assign Domain To Field (Data Management)
If you are willing to look thru my script, and ignore all the stuff that is strictly for my project, I can send you the .py script I use. I will follow you, and if you follow my I can send it email. Too busy to clean it up for general use. But I routinely run a set of scripts to copy my master SDE to a fgdb and pre-process it for Server. One of the steps is reapplying domains and subtypes. It might give you all the info you need. (ig nore this message if someone gives you are cleaner answer).
Have you tried using the ListSubtypes function of the data access module to gather the subtypes for the needed table or feature class?
List Subtypes
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-data-access/listsubtypes.htm
The describe objects may also be useful for this workflow. You should be able to compile a tool that can parse out the subtype names needed and implement your workflow to process them.
GDB Table Properties
http://desktop.arcgis.com/en/desktop/latest/analyze/arcpy-functions/gdb-table-properties.htm
Signed in members can post, follow updates, and more. New here? Register a free account.
