How add correct coordinates to map in wgs 1984?
1484
04-16-2021 11:58 PM
Radzhabad
xy = (47.550976, 42.963041)
array = arcpy.Array()
with arcpy.da.InsertCursor(schetchiki_path,['SHAPE@XY', 'Name']) as c:
    c.insertRow([xy,name])
d9yQZ
DanPatterson
MVP Esteemed Contributor
That must be a partial script because whatever you are trying to do might just add a value to the Shape field but it won't do anything for the fields you have shown in your example
... sort of retired...
curtvprice
See in the help for python examples: Write geometries.
Or (MUCH easier!) create a table with your xy values in it and use the XY Table To Point, or Make XY Event Layer tools to create your points.
DougBrowning
I changed to using Arcade so that the lat/longs are always up to date.  No one remembers to change them when they move a point.  Works great in a web map or ArcPro.
Another option if using SDE is Attribute Rules so that they autoupdate.
WGS 84 in Arcade
CurrentLat
var originShift = 2.0 * PI * 6378137.0 / 2.0;
var lon = (Geometry($feature).x / originShift) * 180.0;
var lat = (Geometry($feature).y / originShift) * 180.0;
lat = 180.0 / PI * (2.0 * Atan( Exp( lat * PI / 180.0)) - PI / 2.0);
return lat;
CurrentLong
return lon;
Make sure to config the popup to show 8 decimals.
Hope that helps.  I know not what you asked but it may work for you.
