Grouping feature classes into feature dataset
2248
11-11-2021 10:17 AM
NatalieRobbins
I have a file structure of nested folders that contains two shapefiles within each. I was to mimic this structure within a geodatabase, where basically each folder would be a feature datasets and the two shapefiles would be feature classes. Is there a way to automate this. My thought would be using the name to group the feature classes into feature datasets.
DanPatterson
MVP Esteemed Contributor
have you tried this? Feature Class To Geodatabase (Conversion)—ArcGIS Pro | Documentation
it mentions feature dataset
... sort of retired...
JoeBorgione
Feature datasets are not designed as a file managment tool.  They are desigined to contain feature classes that have specal related functionality like topology or a network dataset.  If you want to organize your data, I suggest creating a serires of file geodatabases as logical  containers.
That should just about do it....
