Field calculator if statement syntax error.
2125
07-23-2021 03:28 PM
MichaelMarlatt1
I'm using ArcGIS Pro 2.7.
I'm trying to use a python function in the field calculator; which I've done before.  I've got a field with data type Double that we'll call Double_Field that I want to use to determine which value to assign to another field.  Here's what I'm trying:
NewValue(!Double_Field!)
def NewValue(num):
    if num = 0:
        return 1
    elif num > 0 and num <= 3:
        return 2
    elif num > 3 and num <= 6:
        return 3
    elif num > 6 and num <= 9:
        return 4
    elif num > 9 and num <= 12:
        return 5
    elif num > 12:
        return 6
    else:
        return 99
When I try to verify the code I get the following error
I've noticed that if I change the "if num = 0:" to "if num < 0:" or anything but a "=" comparison I no longer get a syntax error (but then code no longer does what I need it to do).
Can anyone help me understand what's going on here?  I'm a little new to Python but not to programming.  It feels a little like a type error but I cannot see how.
Michael Marlatt
Tim_McGinnes
In Python the equals comparison is written as ==, so use
if num == 0:
Tim_McGinnes
if num == 0:
MichaelMarlatt1
Thank you, Tim!
DanPatterson
Another case for divmod
def NewValue(num, divisor=3):
    """Return divmod for a field"""
    val = divmod(num, divisor)[0]
    if val > 6:
        return 99
    return val
[NewValue(i) for i in a]
[0, 1, 2, 3, 4, 5, 6, 99, 99, 99]
a
array([ 0,  3,  6,  9, 12, 15, 18, 21, 24, 27])
... sort of retired...
