Feature Layer Search and Create Feature Layer from Selected Features
3559
03-11-2015 09:46 AM
BradGagliano
I am rather new to arcpy, however I am moving my AddIns from VB.net over to python.  I am trying to search for a feature layer(s) and if found check to see if they have a selection.  If so create a feature layer from that selection. If not do nothing.
I have attached a portion of the code I'm trying to use.
Thanks in advance.
Brad
BlakeTerhune
Assuming this is the snippet of code you're asking about?
for lyr in arcpy.mapping.ListLayers(mxd, "CRASHES1999", df):
    if lyr == "CRASHES1999":
        desc = arcpy.Describe("CRASHES1999")
        in_table = "CRASHES1999"
        field_names = "YEAR"
        if desc.FIDSet:
            with arcpy.da.SearchCursor(in_table, field_names) as cursor:
                for row in cursor:
                    arcpy.MakeFeatureLayer_management(in_table, "SelectedCrashes1999")
        else:
            print "No Features Selected for CRASHES1999"
        del desc
        del in_table
        del field_names
Did you have a specific question or problem? Just guessing, but I see you're passing the field names for the search cursor as a string. According to the documentation, it needs to be a list or tuple. Try this instead:
field_names = ["YEAR"]
BradGagliano
It seems I have answered my own question.
I had
if lyr == "CRASHES1997":
I should have had
if lyr.name == "CRASHES1997":
BlakeTerhune
        if desc.FIDSet:
                for row in cursor:
        else:
        del desc
        del in_table
        del field_names
BradGagliano
Thanks, this did seem to make it run smoother and quicker.
