I wrote a script that exports a title page and a map series. When I run the script manually in PyCharm, the title page exports correctly.
When I set up the script to run in windows task scheduler, the title page exports without the map frame (see image below)
Has anyone come across this and is there a way to fix it?
Here's the code that exports the title page and map series.
proProject = "\\\\Scripts\\Python\\MapBook\\MapBook.aprx"
PDFDir = "\\\\Scripts\\Python\\MapBook\\Output"
p = arcpy.mp.ArcGISProject(proProject)
try:
# Export new title page to pdf
TitleFile = PDFDir + "\\TitlePage.pdf"
tLayout = p.listLayouts("TitlePage")[0]
tLayout.exportToPDF(TitleFile)
print("Exported new title page " + "\n" + arcpy.GetMessages())
mylog.write("Exported new title page" +"\n")
except:
message = arcpy.GetMessages()
print(message)
mylog.write("Error exporting new title page" + message + "\n")
arcpy.AddMessage(message)
mylog.write("Processing Aborted...." + "\n")
sys.exit("Processing Aborted..")
try:
# Export new map book pages to pdf
MBfile = PDFDir + "\\MapPages.pdf"
mbLayout = p.listLayouts("MapPages")[0]
mapSeries = mbLayout.mapSeries
if mapSeries.enabled:
mapSeries.refresh()
mapSeries.exportToPDF(MBfile)
print("Exported new map pages" + "\n" + arcpy.GetMessages())
mylog.write("Exported new new map pages" +"\n")
except:
print(message)
mylog.write("Error exporting new map pages" + message + "\n")
The issue was that the grid was in a database outside of the Pro project. Once the grid was moved to Pro project, the script ran correctly in task scheduler.
I've not come across this, but it would be helpful if we could see some of the code being run.
