export a Python script to a model
1563
03-03-2022 04:22 PM
Chelsea_Trusdell
can export a model from ModelBuilder to a Python script, but you can’t export a Python script to a model. Explain why you can’t export a Python script to a model
ABishop
Hello Chelsea,
There is a way to create a script tool inside a toolbox then add it to the model as part of your workflow.  See this tutorial: https://pro.arcgis.com/en/pro-app/2.8/arcpy/geoprocessing_and_python/adding-a-script-tool.htm
After you create the script tool, you can add it to your model.
Hope this helps!
Amanda Bishop, GISP
ABishop
Hello Chelsea,
Are you using ArcMap or ArcGIS Pro?
Amanda Bishop, GISP
Chelsea_Trusdell
hello, Arcpro
ABishop
Hello Chelsea,
Hope this helps!
Amanda Bishop, GISP
