Esri Example script erroring out with my server
1707
10-30-2020 02:00 PM
JoeWeyl
Hi -
My GIS Server site (non Portal) has a lot of services and folders. I am trying to generate an output listing of the server because I am migrating to a new server. This inventory will help me figure out what I need to move to the new environment.
The script came from here: Example: Write properties of all services to a CSV file—ArcGIS Server | Documentation for ArcGIS Ent...
But when it is trying to write the output to CSV, I am getting the following error message:
line 373, in main
ln = str(jsonOBJ["serviceName"]) + "," + folder + "," + str(item["type"]) + "," + jsonOBJStatus['realTimeState'] + "," + str(jsonOBJ["minInstancesPerNode"]) + "," + str(jsonOBJ["maxInstancesPerNode"]) + "," + "NA" + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["maxRecordCount"]) + "," + str(jsonOBJ["clusterName"]) + "," + "NA" + "," + "NA" + "," + str(jsonOBJ["properties"]["outputDir"]) +"\n"
KeyError: 'maxRecordCount'
It looks to me like this error is from the Service Properties for MaxRecourds, defined under the service parameters, but I am not sure. I still working on it, but if anyone has any insight that would be great.
Tags (1)
DanPatterson
MVP Esteemed Contributor
means there is something wrong with the dictionary key maxRecordCount ... do you have a value for it?
... sort of retired...
JoeWeyl
I ran the code as is, I didn't set anything.
