ERROR 000732 View does not exist or unsupported after 10.3 upgrade
12150
14
04-17-2015 08:38 AM
BugPie
We have a few models that update a point and polygon feature class in our DB a few times a day using a view into our projects DB. We have exported this to py and made a small change "arcpy.env.overwriteOutput = True" and set to run using windows task manager. All good until we moved our beta to 10.3 earlier this week. I realized after a few days that the script was failing in task manager.
I ran the script in Idle to see if I could trace the problem. Viola... this is what we see.
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: XY Table: Dataset Database Connections\inserrtservername.sde\EBISDE.dbo.project_tel_new_vw does not exist or is not supported
Failed to execute (MakeXYEventLayer).
The view works. I return records when I view in SSMS and Catalog. The model works, and writes new features to the features in the DB. I even deleted my DB connection in catalog, made a new one. Opened the models and re-pointed the GP tools to the view and features hoping this would clear up any mis-matched connection names etc. and export to python.
What happened at 10.3 that python is unable to make the DB connection? Seems straight forward, but I'm stumped.
SamuelTompsett
Hello Collin,
Thanks for posting the script.
Have you tried giving the full path to the database connections? Especially for the input view?
Sam
JoshuaBixby
MVP Esteemed Contributor
You had this exact workflow working on this exact machine using an earlier version?  What version?
BugPie
I've been digging. IT made a change in that they moved this virtual server to a new physical machine. Is that possibly in play? All variables including the SQL are located on this machine so I can't imagine it is?
Otherwise, yes same workflow. Only real change was we went from 10.1 SP1 to 10.3 where I suspect the problem is.
Full connection path:
ERROR 000732: XY Table: Dataset Database Connections\washout.sde\EBISDE.dbo.project_tel_new_vw does not exist or is not supported
MichaelVolz
Collin:
You might need to provide the full path to the database connection, if you are not already doing so.
Are you running this script on a Windows Server?  If so, is the new server the same version as the old server?
BugPie
Yes, this script is being utilized from a Windows Server 2008r2 standard SP 1. Both before the physical move and afterwards. Nothing in the Virtual env. has changed.
SamuelTompsett
Can you please post the script? It would be easier for people to look at it directly.
Thanks.
BugPie
Whoops, sorry, that would be helpful. I have attached a zip to this entry that contains a script that is now failing in what looks to be the connection to the DB. Thanks in advance!
SamuelTompsett
Hello Collin,
Sam
BugPie
HI Sam,
No I have not tried that approach yet. I haven't done much yet, wanted to wait on what the community thought before I started anything new other than re-exporting from 10.3.  I will look into your suggestion and report back later.
Thank you !!
BugPie
This was the solution. Thank you Sam.
Any ideas if this change is due to 10.3? I'd like to get a better understanding of the underlying cause.
