ERROR 000707: Spatial reference of the tiling scheme does not match the spatial reference of the map
4684
02-22-2021 04:17 AM
CliveSwan
Greetings,
I am trying to export an ArcGIS Pro project to a Vector Tile Package.
I am getting an ERROR 000707: Spatial reference of the tiling scheme does not match the spatial reference of the map
I found an ESRI Support posting that stated change the Map projection to WGS 1984 Web Mercator projection. I updated the Map projection to WGS 1984 Web Mercator:
I am still getting ExecuteError: ERROR 000707
Any suggestions??
Regards,
Clive
DanPatterson
MVP Esteemed Contributor
What is the coordinate system of your map?  Did you do the extra steps?
000707: Spatial reference of the tiling scheme does not match the spatial reference of the map.—ArcG...
... sort of retired...
CliveSwan
Hi Dan,
Thanks for the email.
This is a new export from ArcGIS Pro to a VectorTilePackage
My understanding is ESRI default tiling SRS is EPSG: 3857. Both the Map and  the Layers have been projected from BNG:27700  to EPSG: 3857.
Regards,
Clive
DanPatterson
Not seeing anything else except for saving the project since all the layers and map are the same.  No listed bugs either.  A swift reboot? and try again?
CliveSwan
Get through one error message and ESRI has another for you..  I created a .vtpk file, trying to export it to portal, using the ESRI example
It threw an error message, then it ran..  🙂
