Edit Feature Layers Without Arcpy
1130
03-25-2024 05:06 AM
CodyPatterson
MVP Regular Contributor
Hey All,
Enterprise 11.2
We're attempting to create a Python script that will take information from a feature layer, check to see if it has a certain attribute, if not, it will Geocode that address and then run an intersect based on that XY coordinate to see if it lands in a polygon, if it does, it will copy that polygon and insert it into a different feature layer.
This would be incredibly easy, trivial even with ArcPy, but unfortunately, ArcPy is held behind the Notebook Advanced runtime, and we only have the Standard Runtime.
I am considering using the Python API for ArcGIS, but I was curious if anyone had any ideas before I jumped into that.
I am open to any recommendations or suggestions.
Thanks in advance!
Cody
Clubdebambos
Hi Cody,
You can definitely achieve this with the ArcGIS API for Python. If automating in ArcGIS Online/Portal my first port of call would be to use the ArcGIS API for Python. While ArcPy works with Feature Layers, I have found data/table corruptions to occur from time to time, especially with any schema alterations, but never with the API (to date!). Only if something is not achievable with the API, then I switch to ArcPy.
~ learn.finaldraftmapping.com
forestknutsen1
MVP Alum
