System: Windows Vista and ArcGIS 9.3Hello, I have 100 shapefiles called geocXXXX.shp (geoc0782, geoc9838, and geoc6728 etc)In each shapefile, there is a field call CXXXX (C0782, C9838, and C6728 etc).The field property is string, length =6.Also, there are other fields called CXXXXMS and CXXXXMW (C0782MS and C0782MW).The field property is long integer, length =9.I would like to delete the fields of CXXXX, CXXXXMS, and CXXXXMW at the same time.However, the following code did not work.Please kindly advise how to modify it and thank you.#Import standard library modules import arcgisscripting import os #Create the Geoprocessor object gp = arcgisscripting.create(9.3) #Set the input workspace #GP.workspace = sys.argv[1] #Set the workspace. gp.Workspace= "H:/temp_D/test" #Set the output workspace #outWorkspace = sys.argv[2] #Set the workspace. List all of the feature classes in the dataset outWorkspace= "H:/temp_D" #Get a list of the featureclasses in the input folder fcs = gp.ListFeatureClasses() # Loop through every item in the list that was just generated for fc in fcs: # delete the field CXXXX gp.deletefield (fc, "C*") gp.AddMessage(gp.GetMessages()) print gp.GetMessages()
