Creating feature class
2109
10-01-2016 02:21 PM
ChiamakaOyekwe-Madumelu1
I am trying to create a road shape file but i keep getting errors when i run my code in pycharm.
arcpy.management.CreateFeatureclass(r"C:\Users\cxo121730\Desktop\site 5", "Road", "POLYLINE", r"C:\Users\cxo121730\Desktop\Redlands.gdb\Railroads", "SAME_AS_TEMPLATE", "SAME_AS_TEMPLATE", "PROJCS['NAD_1983_UTM_Zone_11N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-117.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision", None, 0, 0, 0)
DanPatterson_Retired
Create Feature Class—Help | ArcGIS for Desktop
try it without the template, remove the spaces from the featureclass name, and lastly can you do it through arccatalog.  If you can't, then there is something wrong with the destination gdb.  and lastly, lastly, save it somewhere else
Thanks Dan,
It worked
