Creating evaluation units from segmented stream buffers
1280
06-13-2012 12:14 PM
BethanyNoordegraaf
My task is to ensure that 75% of a stream length is 'vegetated' to 30m. I am trying to follow a work flow that suggests segmenting a stream every 100m and then use Euclidean allocation to create various buffers. By segmenting and then buffering the stream I will then have 'evaluation units' that can be used to manipulate land cover. My question is, using python, how could I divide the stream segments of a shapefile into subsegments every 100m, having these sub-segments maintain a link to their original full stream segment. Once I have these subsegments, can a Euclidean allocation function be easily applied to attain evaluation units that maintain information about adjacent evaluation units? Any help on this one would be greatly appreciated 🙂
ThaiTruong
Hi Bethany,
There is a Split Polyline by distance script  in ArcGIS Resource Center to help split a polyline into equal segments using a given length.  Hope that it helps you to complete your task.
