Creating a Line at a Right Angle to another line?
2270
02-22-2012 03:57 AM
FrederiqueLemieux
Hello,
I have a shapefile which contains many lines features.  I would like to create a python script that will create a line and the start and end of each line, at a right angle, and a set length.
I know it will require a little trig calculations which I am happy with, but I would need to get information about the line, i.e. the cooridinates of the start and end point, the angle of the line from those points (I'm not sure how information about line shapefiles are stored)....
And then from that information create a line using python script.
Could someone point me in the right direction on how I would do this?
Thanks in advance.
curtvprice
You can read geometry and create features using cursors. It's a little tricky (and slow) but it can be done.
Here's the help on that:
Arc" rel="nofollow" target="_blank">http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//0... 10 Help: Working with geometry in Python
Be sure and avoid doing all the geometry yourself, there are some very handy functions in the standard library, especially math.
Field Calculator supports a lot of calculations too - if you want store things in the attribute table:
[post=169592]Common Python geometry calculations in the Field Calculator [/post]
FrederiqueLemieux
Sorry to sound a little ignorant, just getting into the Python world, but what is Mathlib and how is it accessed?
Regards
curtvprice
math (sorry) is a module that is part of the standard library, ie it's in all python distributions.
>>> import math
>>> help(math)
If you're new to Python, be sure and check out:
Brief" rel="nofollow" target="_blank">http://docs.python.org/tutorial/stdlib.html]Brief Tour of the Standard Library
KimOllivier
Honored Contributor
Here is a similar problem I had a long time ago. I needed to draw a right angled line across the road at each drain (cunvert) point that was recorded in an asset management system. ArcIMS could not handle linear referencing. I got the angles by using MakeRouteEventLayer, then it was just a matter of creating a new line.
It could be a lot more elegant at 10.x but the maths is the same. I wrote out to a file and used the sample/CreateFeaturesFromTextFile, now deprecated and removed.
# culvert.py
# create culvert lines from point events
# must have loc_angle and length_m fields
# default length_m is 10 metres
# angle is from event wizard which is parallel to road
# which must be wrong at 9.1
# Input
# arg1 point event layer
# arg2 loc_angle field
# arg3 length_m field
# arg4 output featureclass
# projection from event layer
# Kim Ollivier
# 26 September 2006
import sys, string, os, win32com.client, math
def newculvert(strID,strX,strY,strAngle,strSize) :
    Create a line array at right angles to angle
    and add to new featureclass already defined
    id = int(strID)
    x0 = float(strX)
    y0 = float(strY)
    radAngle = float(strAngle) / 180.0 * 3.14159
    size = float(strSize) / 2.0
    if size == 0 :
        size = 10
    x1 = x0 - size * math.cos(radAngle)
    y1 = y0 - size * math.sin(radAngle)
    x2 = x0 + size * math.cos(radAngle)
    y2 = y0 + size * math.sin(radAngle)
    # print "%8d %12.3f %12.3f %8.3f %4.1f" % (id,x0,y0,angle,size)
    # print "            %12.3f %12.3f %12.3f %12.3f" % (dx1,dy1,dx2,dy2)
    print >> f1,"%d 0" % id
    print >> f1,"0 %f %f 0.0 0.0" % (x1,y1)
    print >> f1,"1 %f %f 0.0 0.0" % (x2,y2)
    return True
#----------------- main -----------------
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
if len(sys.argv) != 6 :
    print "Need 6 parameters, setting defaults for debugging"
    strInputFeatureClass = "e:/council/clutha/shape/culvert3.shp"
    strIDField = "DRAIN_ID"
    strAngleField = "LOC_ANGLE"
    strSizeField = "LENGTH_M"
    strOutputFeatureClass = "e:/council/clutha/shape/culvert_ln.shp"
else :
    strInputFeatureClass = sys.argv[1]
    strIDField = sys.argv[2]
    strAngleField = sys.argv[3]
    strSizeField = sys.argv[4]
    strOutputFeatureClass = sys.argv[5]
if not os.path.exists(strInputFeatureClass) :
    print strInputFeatureClass,"not found"
    sys.exit()
# set the directory and workspace to the source shapefile location
os.chdir(os.path.dirname(strInputFeatureClass))
gp.Workspace = os.path.dirname(strInputFeatureClass)
f1 = open("culvert.txt","w")
print >> f1,"Polyline"
# Find the name of the shape field using Describe.
strShapeFieldName = gp.Describe(strInputFeatureClass).ShapeFieldName
# Check other fields are correct
eFlds = gp.ListFields(strInputFeatureClass)
fld = eFlds.Next()
fldOk = False
print gp.GetCount_management(strInputFeatureClass),"gp count"
while fld :
    if fld.Name.upper() == strIDField.upper() :
        fldIDOk = True
    if fld.Name.upper() == strAngleField.upper() :
        fldAngleOk = True
    if fld.Name.upper() == strSizeField.upper() :
        fldSizeOk = True
    fld = eFlds.Next()
if not fldIDOk:
    strErr = "No ID field found "+strIDField
    gp.AddError(strErr)
    print strErr
else :
    print strIDField," found"
if not fldAngleOk:
    strErr = "No Angle field found "+strAngleField
    gp.AddError(strErr)
    print strErr
else :
    print strAngleField," found"
if not fldSizeOk:
    strErr = "No Size field found "+strSizeField
    gp.AddError(strErr)
    print strErr
else :
    print strSizeField," found"
if not (fldIDOk or fldAngleOk or fldSizeOk) :
    print "Fatal error in field names"
    sys.exit(2)
nCulvert = 0
# open a Search Cursor
objRowList = gp.SearchCursor(strInputFeatureClass)
objRow = objRowList.Next()
try :
    while objRow:
        objGeometry = objRow.GetValue(strShapeFieldName)
        objPart = objGeometry.GetPart(0)
        strX = objPart.X
        strY = objPart.Y
        strID = objRow.getValue(strIDField)
        strAngle = objRow.GetValue(strAngleField)
        strSize = objRow.GetValue(strSizeField)
        # create a new line feature
        ok = newculvert(strID,strX,strY,strAngle,strSize)
        if ok :
            nCulvert += 1
        # cleanup or looks like a memory leak
        del objRow, objPart, objGeometry
except Exception, e :
    print e
    gp.AddError(e)
    print "Error in Search Cursor"
    print gp.GetMessages()
    gp.AddError("Error in Search Cursor")
    sys.exit(2)
print >> f1,"END"
f1.close()
print nCulvert,"culverts total"
gp.AddMessage(str(nCulvert)+" culverts found")
# create a shapefile
gp.OverwriteOutput = 1
test = "culvert_ln.shp"
gp.CreateFeaturesFromTextFile("culvert.txt",".",test,"")
print "Created new shapefile",test
FrederiqueLemieux
Thanks! I'll give this a go this week.
Will let you know how I get on.
Thanks
