Create script for advanced feature labelling
2933
05-24-2021 08:02 PM
DavidField
I am trying to work out if it is possible to create a script for ArcGIS Pro that allows me to turn on labels for a feature, and then lets me control:
-colour
-font size
-halo on / off
-halo colour
-halo width
Ideally the script would have user-defined inputs for all of the above.
It seems that this may be possible in ArcMap, but I can't seem to find any discussion for ArcGIS Pro. Can anyone point me to documentation, code samples or a tutorials that might get me started?
Cheers
DavidField
I was thinking something along the lines of the following code might work, but it only seems to affect the halo width, all other properties are unchanged:
featurename = arcpy.GetParameterAsText(0)
labelcolumn = str(arcpy.GetParameterAsText(1))
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.activeMap
for lyr in m.listLayers(featurename):
lblClass = lyr.listLabelClasses()[0]
lblClass.expression = "[" + labelcolumn + "]"
# Get the layer's CIM definition
l_cim = lyr.getDefinition('V2')
# Get first label class
lc = l_cim.labelClasses[0]
# Set label class symbol properties
lc.textSymbol.symbol.color = 'white'
lc.textSymbol.symbol.font = 8
lc.textSymbol.symbol.haloColor = 'black'
lc.textSymbol.symbol.haloSize = 1
# Set layer's CIM definition
lyr.setDefinition(l_cim)
# Show labels
lyr.showLabels = True
mody_buchbinder
I just add tags. See this: https://pro.arcgis.com/en/pro-app/latest/help/mapping/text/text-formatting-tags.htm
Then you change the expression only.
It works for me
DavidField
Thanks for your reply!
I had a look at tags, they look much more user-friendly, however I don't think they will allow me to adjust halo settings?
