Create File GDB and store as variable
6534
10
03-28-2019 07:17 AM
RyanF
I'm working on a script that originally had locations coded in but I want to make it where anyone in my office can use it and they can set their workspace up however they want. I've almost got it to work how I want. I think I have one more obstacle then I'm good.
I have some parameters set up for user input.
arcpy.env.workspace = arcpy.GetParameterAsText(0)
FileGDB_name = arcpy.GetParameterAsText(1)
NewLocation = arcpy.CreateFileGDB_management(arcpy.env.workspace, FildGDB_Name)
clipLayer = arcpy.Clip_analysis(RouteLayer, StateLayer, NewLocation + name + "Clip")
RouteLayer and StateLayer are additional parameters set up by the user. The script fails when it gets to the clip tool. I realize the way I have it set up, NewLocation calls the CreateFileGDB tool rather than the location of the GDB. I want to be able to create the GDB and store it as a variable so it can be used in other tools in the script. Could someone shed some light on how to do this?
Thanks!
JoshuaBixby
MVP Esteemed Contributor
Please mark someone's answer correct to close out the question.  Thanks.
