Create dimension using arcpy
2688
12-26-2021 02:13 PM
Khalid_Elejla
How, can I create dimensions using arcpy
I was able to create polygons for example, but when it comes to dimensions I can't figure the right inputs to the class
Also, I found out that there is a class called arcpy. Dimension but it looks like it's empty compari g to polygon, polyline or point class
DanPatterson
MVP Esteemed Contributor
Geometry construction is found in the help topics
Geometry—ArcGIS Pro | Documentation
and there are links for Polygon, polyline etc.
What type of "dimension" are you referring to if it is no a spatial dimension? time?
... sort of retired...
Khalid_Elejla
Thanks, Dan.
I am referring to the dimension feature class, I have a dimension layer and I want to add more dimensions(aligned dimension for example) to my map using arcpy
I use the following code to add polygons to my feature dataset but I couldn't do the same to the dimension layer using arcpy.Dimension class:
import arcpy
# Create a polygon geometry
array = arcpy.Array([arcpy.Point(0, 0),
                     arcpy.Point(0, 1000),
                     arcpy.Point(20, 900)
polygon = arcpy.Polygon(array)
# Open an InsertCursor and insert the new geometry
cursor = arcpy.da.InsertCursor(r'C:\Users\kejla\Documents\ArcGIS\Projects\Gaza_Municapility\Default.gdb\test_polygon', ['SHAPE@'])
cursor.insertRow([polygon])
# Delete cursor object
del cursor
DanPatterson
A polygon needs 4 points to form a triangle, you need to add the first point to the end of the list to close the polygon
Khalid_Elejla
I don't have problems in creating polygons, could you please guide me on how to do the same for the dimension layer, in other words how to add new dimension using arcpy
DanPatterson
There is no "arcpy" method of creating one from scratch.
Create a dimension feature class—ArcGIS Pro | Documentation
is all I can find
