CONNECTIVITY SCRIPT OF WALKABILITY INDEX FAILED! NEED HELP.
1365
03-09-2023 07:16 AM
AuzanPahlevi
Executing: Connect C:\Users\Pijem\Downloads\Arcgis\TA\URBANAREANEW.shp C:\Users\Pijem\Downloads\Arcgis\TA\SEGMENJALANNEW.shp Klasifikas H C:\Users\Pijem\Downloads\Arcgis\TA\TGLNEW.shp code W I 15 false
Start Time: Thu Mar 09 22:04:52 2023
Running script Connect...
c:\users\pijem\appdata\local\temp\tmpscidaf
Input
Failed script Connect...
File "C:\Users\Pijem\Downloads\Arcgis\PRO\WAI_v10\connect.py", line 45, in <module>
sql=arcpy.GetParameterAsText(10)
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\__init__.py", line 655, in GetParameterAsText
return gp.getParameterAsText(index)
File "c:\program files (x86)\arcgis\desktop10.4\arcpy\arcpy\geoprocessing\_base.py", line 226, in getParameterAsText
self._gp.GetParameterAsText(*gp_fixargs(args, True)))
RuntimeError: Object: Error in getting parameter as text
Failed to execute (Connect).
Failed at Thu Mar 09 22:04:53 2023 (Elapsed Time: 1,13 seconds)
Anyone can fix this problem? Tq:)
CarlSunderman
I think you will need to post the code to get some help. It looks like there are issues with the input parameters
