Conditioning labels
8274
12
02-10-2015 10:56 AM
Ulises
Hi everyone,
I'm trying to define an expression for labeling parcel polygons in ArcMap.  The feature class has 3 attributes of interest: CATEGORIA, NUM_CATASTRO, and PARCEL_SP.  If CATEGORIA (integer field with subtypes defined) is not 0 (N/A), then label the polygon with the value in PARCEL_SP, otherwise label with NUM_CATASTRO.  I'm not a programmer and I'm just starting with Python so I'm not sure what is missing.  So far I have...
def FindLabel (  [CATEGORIA],[NUM_CATASTRO], [PARCEL_SP] ):
  if [CATEGORIA] ==0:
    return [PARCEL_SP]
  else:
    return  [NUM_CATASTRO]
The issue is that I can see labels for NUM_CATASTRO where they should, but none for PARCEL_SP.
If I reverse the values...
  if [CATEGORIA] ==0:
  else:
    return [PARCEL_SP]
it labels the PARCEL_SP where is supposed to but not the NUM_CATASTRO.
Same thing using the following statement...
  if [CATEGORIA] !=0:
    return   [PARCEL_SP]
  else:
Any help will be appreciated...
Ulises Feliciano Troche
Ulises
I tried with VBScript and it worked.  After banging my head for a while against the monitor I decided to try one last thing before a break...RESTART ArcMap.
Then get back to Python and tried again...IT WORKED!!!
Don't really know what happened, but Tom's suggestion make me try using the string value for the subtype instead of the number and it worked.  The final code is like this...
  if [CATEGORIA] =='N/A':
  else:
    return "<CLR red='255'><FNT size = '10'>" +  [CATEGORIA] + "</FNT></CLR> <CLR blue='255'> \n" + [PARCEL_SP] + "</CLR>"
Find it weird that I needed to use the description instead of the integer value for the subtype field.
Thanks again for the help and suggestions.
TomSellsted
Ulises,
Perfect!  Glad that worked for you!  Please mark the answer as correct too!
Regards,
Tom
Zeke
Honored Contributor
Maybe post a screenshot of part of your attribute table.
