Compare Feature and attribute
12850
11
10-03-2011 10:33 PM
AshutoshGosavi
Q1 I have a small question.
I want to compare two shape files with attribute and shape feature.
After the comparison is done it should display the miss match in attribute and shape features.
Is there a inbuilt tool in Arcgis or does it need to be scripted.
Regards
Ashutosh
NicholasO_Connor
Cheers Kim - now all is clear. Thank you. Perhaps it was too many late nights migrating SDE to 10.2.2. I just needed fresh pair of eyes.
BruceHarold
Esri Frequent Contributor
Data Interoperability extension can compare two arbitrary data sources without any shared key requirement and drop out unchanged/insert/delete or CRUD sets insert/update/delete over any set of geometry or attribute comparisons.  If the scripted approach doesn't work for you email me at [email protected] with sample data and I'll run it.
