Change domains for subtype features
3444
6
04-26-2018 10:20 AM
forestknutsen1
Is there a way to change the domains on a feature class that has sybtypes with arcpy?
2 Solutions
RandyBurton
Check out:
An overview of the Domains toolset
An overview of the Subtypes toolset
You should be able to use these tools to do what you need.
forestknutsen1
My solution:
ListSubtypes—Data Access module | ArcGIS Desktop
Assign Domain To Field—Data Management toolbox | ArcGIS Desktop
import arcpy
sde_path = r"xxxx"
arcpy.env.workspace = sde_path
domain = "T_LineSegment"
domain_feature_classes = {"feature_class": "domain_field", ....}
for feature, domain_field in domain_feature_classes.items():
    print "updating domains by subtype on " + feature
    subtypes = arcpy.da.ListSubtypes(feature)
    for k, v in subtypes.items():
        print "\tsetting domain for subtype code: " + str(k)
        arcpy.AssignDomainToField_management(feature, domain_field, domain, k)
RandyBurton
Check out:
forestknutsen1
I don't see anything in them that will let me set the domain on a field by subtype... unless I am missing something...
RandyBurton
If you are using Pro, there's this:
Create, modify, and delete subtypes
With Desktop, I believe it is a Delete and Add instead of Modify.
forestknutsen1
No we are still on desktop. But I did judge your last post to fast. It is part of the solution I think for sure. I was just being foolish. I am testing now...
forestknutsen1
My solution:
import arcpy
sde_path = r"xxxx"
MaximeDemers
This should be marked as the solution.
