Hi all,
I would like to create a point shape with Z value in ArcMap, for that I was created a tool using python addin toolbar. The tool can get XY coordinates from mouse click on datafreme. Now I want to add Z value as manuel for this point. Can I add Z value from a window by created QWidget or other PyQt4 windows, after got the XY position on dataframe for my point shape. Is there any way to do this using python? Can you kindly give any advices?
My current code:
There is global z in my code, it is just a simple solution and I dont want to use it. You know it isn't useful way.
import arcpy
import pythonaddins
arcpy.env.addOutputsToMap = True
arcpy.CheckExtension('3D')
class Observation_Point(object):
"""Implementation for addin5_addin.tool (Tool)"""
def __init__(self):
self.enabled = True
self.shape = "NONE"
def onMouseDown(self, x, y, button, shift):
pass
def onMouseDownMap(self, x, y, button, shift):
#choose XY on dataframe
mxd = arcpy.mapping.MapDocument("current")
dataframe = arcpy.mapping.ListDataFrames(mxd)[0]
global z
z= 20
PointGeom = arcpy.PointGeometry(arcpy.Point(x,y,z), None, True, False)
global A
A = "C:\\Users\\Casper\\Desktop\\DENEMELER\\obs_point_fromAddin5.shp"
arcpy.CopyFeatures_management(PointGeom, A)
print "saved as a point.shp..."
def onMouseUp(self, x, y, button, shift):
pass
def onMouseUpMap(self, x, y, button, shift):
pass
def onMouseMove(self, x, y, button, shift):
pass
def onMouseMoveMap(self, x, y, button, shift):
pass
def onDblClick(self):
pass
def onKeyDown(self, keycode, shift):
pass
def onKeyUp(self, keycode, shift):
pass
def deactivate(self):
pass
def onCircle(self, circle_geometry):
pass
def onLine(self, line_geometry):
pass
def onRectangle(self, rectangle_geometry):
pass
