Batch Export And Print Script/Tool stopped working in 10.2
8398
8
12-06-2013 07:09 AM
YaroslavZaitsev
Hi all. I have been using below script/tool for a very long time and have gotten used to how easy it was for me to take 100+ maps, click 2 things and come back to beautifully exported or printed dataset. My tool has stopped immediately after we upgraded to 10.2 from 10.0. I am sure it is something as silly as missing a squigly line somewhere. It seems that every release of arcmap is followed by some minor change. Initially with VB to Py I had to source all scripts to make them work and now my main stopped working. Any thoughts/comments would be appreciated. Thank you.
Batch Export and Print
  This script takes MXD files
  and exports all the maps as selected
  @author Steven Porter
  @contact: [email protected]
  @organization: The Voinovich School for Leadership and Public Affairs, Ohio University
  @version 1/20/11
import arcpy, sys, os
#Input variables. Remember arcgis passes lists as semicolon delimited strings (files)
files= sys.argv[1]
yesPDF = sys.argv[2]
yesJPG = sys.argv[3]
yesPNG = sys.argv[4]
yesEMF = sys.argv[5]
yesAI = sys.argv[6]
yesPRINT = sys.argv[7]
printer = sys.argv[8] #relies on code to generate a list in the tool itself
outputFolder = sys.argv[9]
mergePDF = sys.argv[10]
#if outputFolder is empty use mxd location
if outputFolder=="#":
 outputFolder = os.path.dirname(files.split(";")[0])
if yesPDF=="true" and mergePDF =="true":
  combinedpdf = arcpy.mapping.PDFDocumentCreate(outputFolder + os.sep + "CombinedMaps.pdf")
#loop through each passed mxd file split the string back into the list
for file in files.split(";"):
 file=file.strip("'")
 #parse out the file name of the file
 filename = os.path.basename(file)
 #get the name of file without any file extension
 mxd_name = filename.split(".")[0]
 #create a map object from the file
 map = arcpy.mapping
 map_document = map.MapDocument(file)
 #Check for broken data sources
 brokenList = arcpy.mapping.ListBrokenDataSources(map_document)
 if brokenList:
  errorString = filename+" has broken data sources on layer(s): "
  for item in brokenList:
   errorString = errorString + "'"+item.name+"'"
  arcpy.AddError(errorString)
 # Set all the parameters as variables here:
 data_frame = 'PAGE_LAYOUT'
 resolution = "300"
 image_quality = "NORMAL"
 colorspace = "RGB"
 compress_vectors = "True"
 image_compression = "DEFLATE"
 picture_symbol = 'RASTERIZE_BITMAP'
 convert_markers = "TRUE"
 embed_fonts = "True"
 layers_attributes = "NONE"
 georef_info = "False"
 #perform selected operations
 if yesPDF=="true":
  arcpy.AddMessage("Exporting: "+ filename+" as PDF")
  out_pdf = outputFolder + os.sep + mxd_name+ ".pdf"
  map.ExportToPDF(map_document, out_pdf, data_frame, 640, 480, resolution, image_quality, colorspace, compress_vectors, image_compression, picture_symbol, convert_markers, embed_fonts, layers_attributes, georef_info)
  if mergePDF =="true":
   combinedpdf.appendPages(out_pdf)
 if yesJPG=="true":
  arcpy.AddMessage("Exporting: "+ filename+" as JPEG")
  out_jpg = outputFolder + os.sep + mxd_name+ ".jpg"
  map.ExportToJPEG(map_document, out_jpg)
 if yesPNG=="true":
  arcpy.AddMessage("Exporting: "+ filename+" as PNG")
  out_png = outputFolder + os.sep + mxd_name+ ".png"
  map.ExportToPNG(map_document, out_png, data_frame, 640, 480, resolution)
 if yesEMF=="true":
  arcpy.AddMessage("Exporting: "+ filename+" as EMF")
  out_emf= outputFolder + os.sep + mxd_name+ ".emf"
  map.ExportToEMF(map_document, out_emf, data_frame, 640, 480, resolution, image_quality, "#", picture_symbol, convert_markers)
 if yesAI=="true":
  arcpy.AddMessage("Exporting: "+ filename+" as AI")
  out_AI= outputFolder + os.sep + mxd_name+ ".ai"
  map.ExportToAI(map_document, out_AI)
 if yesPRINT=="true":
  arcpy.AddMessage("Printing: "+filename)
  map.PrintMap(map_document, printer)
 del map #delete the map opject
  combinedpdf.saveAndClose()
  del combinedpdf
# This gives feedback in the script tool dialog
arcpy.GetMessages()
JeffBarrette
How has it stopped working?
Do you have a line number or error message to help narrow down the issue?
Jeff
YaroslavZaitsev
It just stopped working. It goes into red X and halts the script and does not produce any error messages. But when I put the text into IDLE to run the tool it tells me that there is an error on line 15
  File "G:\share\arcgis\toolboxes\BatchExportandPrint.py", line 15, in <module>
    files= sys.argv[1]
IndexError: list index out of range
I have taken a few python classes in past couple of years. I think this error means that there are no variables... ok since this is a script and script came with a tool referring to the script. In tool you specify arguments (aka inputs)
In Arcmap itself it does this:
It accepts all the maps and runs the tool and then nothing happens. I see a red X saying tool did not run. A little failure window does not pop up and no error message shows up. Please see attached screenshot.
MichaelNorelli
I ran this successfully in ArcMap 10.2.1...
MichaelNorelli
...by doing this:
I downloaded the whole toolbox and bin directory from here: snowballsteve/ArcGIS_Scripts · GitHub
Under the toolboxes directory: C:\Users\<user>\AppData\Roaming\ESRI\Desktop10.2\ArcToolbox
I stored the bin directory containing the python script above in ..\My Toolboxes\bin.  The toolbox this script is called from, ArcGIS_Scripts.tbx, I stored in ..\MyToolboxes.
In ArcMap, I open Catalog > Toolboxes > My Toolboxes > ArcGIS_Scripts.tbx, and underneath is "Batch Export and Print".
Right-clicking and choosing Properties, I can see that the script above is listed under the Source tab as the Script File.
In the Parameters tab, I can see these:
Input MXD Documents
PDF
JPG
PNG
EMF
AI
PRINT
Printer
Output Folder
Merge PDF
Double-clicking the tool runs it.  This pops up the dialog where I specify my directory of MXDs and the checkboxes to say what I want done with them.
Runs with no errors and nice outputs!
DanielleLee
This worked perfectly for me! Thank you.
Seanmmm
Anyone have any luck with this in 10.5?? I'm getting the same thing as OP with his script, mysterious red X.
RhettZufelt
MVP Notable Contributor
How are you running this tool?  It appears as if it is not getting the sys.argv[1] passes to the script.
If a script tool, might want to check the properties and make sure all the parameter info is correct.
R_
MatejCunder
I was struggling with the same problem; the code just stopped working.
I finally found a solution, that wokrs for me.
In the scipt properties check the options: "Always run in foreground"
BR,
Matej
