arcpy
5525
12
03-12-2021 02:25 AM
Mick
Can you explain why I have problems with 'with open(out, "w") as k:'? I would like to create a script to use for ArcGIS to add to each file in the folder with text extension 'Hellow'.
I guess everything because of fileName[:-4] + ".txt",so Python can not define and write in each file.  However, I don't know how to correct it.
import arcpy
inPut = r'C:\12'
arcpy.env.workspace = inPut
myList = arcpy.ListFiles()
for fileName in myList:
if fileName.endswith(".txt"):
     out = fileName[:-4] + ".txt"
         k.write('Hellow')
Mick
I see. Thank you. Your method deletes everything inside the files and replaces it for only 'Hellow'.
DavidPike
MVP Notable Contributor
Yes, your method would have done the same, it's the 'w' write argument which replaces a file if it exists.
python - Difference between modes a, a+, w, w+, and r+ in built-in open function? - Stack Overflow
you may wish to use the 'a' append argument or others.
inPut = r'D:\Downloads\aatester'
       out = inPut + "\\" + fileName[:-4] + ".txt"
       print(out)
       with open(out, "a") as k:
         k.write('Hellow')
BlakeTerhune
Sorry if I convolute this situation more for you @Mick , but I just want to add that you can use a wildcard argument with ListFiles() to only return txt files.
import arcpy
import os
myList = arcpy.ListFiles("*.txt")
    out = os.path.join(inPut, f"{fileName[:-4]}.txt")
    print(out)
        k.write('Hellow')
Additionally, I updated your path construction to use os.path.join() so it reliably does the separator. You will also notice the f string formatting for the file name. This will function the same but I just wanted to demonstrate there are multiple ways to accomplish something.
