Arcpy query data and switch selection
1931
03-04-2021 12:38 PM
JoseSanchez
Hello everyone
Its looks like these two cases  produce the same results:
querySAOall = populated with a condition
# Make feature layer from my input data
arcpy.MakeFeatureLayer_management(inSAO, "LayerAll")
# Select by attribute and switch the selection
arcpy.SelectLayerByAttribute_management ("LayerAll", "NEW_SELECTION", querySAOall)
arcpy.SelectLayerByAttribute_management ("LayerAll", "SWITCH_SELECTION")
or:
arcpy.MakeFeatureLayer_management(inSAO, "LayerAll", querySAOall)
For me in the second case, the second  "arcpy.SelectLayerByAttribute_management" line should return 0 because it is trying to select  from a "SWITCH_SELECTION", and in the previous arcpy.MakeFeatureLayer_managemen we only select records with the condition querySAOall
arcpy.MakeFeatureLayer_management(inSAO", "LayerAll", querySAOall) arcpy.SelectLayerByAttribute_management ("LayerAll", "SWITCH_SELECTION")
Please advise.
DavidPike
MVP Notable Contributor
I dont think the query in makefeaturesmanagement is making a layer where those features matching the query are selected, rather it is creating a layer which is a subset which matches the query.
The switch selection is therefore taking none selected to all selected.
JoshuaBixby
MVP Esteemed Contributor
David is correct, passing an SQL WHERE clause to MakeFeatureLayer creates a layer with a DefinitionQuery set to the SQL WHERE clause.  The definition query is separate from selections and applies before the Select By tools.
