ArcPy.mp Get Selected Features Extent
7391
7
01-30-2020 10:00 AM
EmmaBell-Carruthers1
I am trying to get the extent of the selected features in arcpy to pass into CreateFishnet. Currently I have it working so it will only create a fishnet for the last selected feature because it is just looping through the rows of the features. I have copied the code below. Any help would  be great.
import arcpy
arcpy.env.overwriteOutput = True
cellSize = 50
sa = 2500
fullPlots = 0
halfPlots = 0
blockNum = arcpy.da.SearchCursor("L3OpSilv", "BLOCK_").next()[0]
whereClause = "BLOCK_ = '{0}'".format(blockNum)
#arcpy.AddMessage(whereClause)
with arcpy.da.SearchCursor('L3OpSilv', ["BLOCK_","SHAPE@"], whereClause) as rows:
    for row in rows:
        pLowerLeft = str(row[1].extent.lowerLeft)
        pUpperRight = str(row[1].extent.upperRight)
        fullExtent = row[1].extent
        extXMin = row[1].extent.XMin
        #arcpy.AddMessage(row[1].extent.YMin)
        extYMin = str(row[1].extent.YMin + 10)
        #arcpy.AddMessage(extYMin)
yAxisCoord = (str(extXMin) + " " + str(extYMin))
arcpy.management.CreateFishnet('fullextentfishnet', pLowerLeft, yAxisCoord, cellSize, cellSize, None, None, pUpperRight, 'NO_LABELS', fullExtent, 'Polygon')
fishnetclipped = arcpy.Clip_analysis('fullextentfishnet', 'L3OpSilv', 'fishnetclip')
DavidPike
MVP Notable Contributor
What do you want to happen or what is not working? I'm sorry I don't understand the question.
DavidPike
import arcpy
cellSize = 50
sa = 2500
fullPlots = 0
halfPlots = 0
blockNum_list = [ ]
with arcpy.da.SearchCursor("L3OpSilv", "BLOCK_") as cursor:
    for row in cursor:
        blockNum_list.append(row[0])
blockNum_set = set(blockNum_list)
for blockNum in blockNum_set :
    whereClause = "BLOCK_ = " + "'" + blockNum + "'"
    counter == 0
    with arcpy.da.SearchCursor('L3OpSilv', ["BLOCK_","SHAPE@"], whereClause) as cursor:
        for row in cursor:
            counter += 1
            full_fishnet_path = "Fishnet_" + blockNum + "_" + str(counter)
            clipped_fishnet_path = "Fishnet_" + blockNum + "_" + str(counter) + "clip"
            arcpy.management.CreateFishnet(full_fishnet_path, pLowerLeft, yAxisCoord,       cellSize, cellSize, None, None, pUpperRight, 'NO_LABELS', fullExtent, 'Polygon')
            fishnetclipped = arcpy.Clip_analysis(clipped_fishnet_path, 'L3OpSilv', 'fishnetclip')
Currently if I have 3 separate polygons features selected all in the same layer. The fishnet is only created over the last feature that is selected and my other 2 selected polygons have no fishnet overlapping them. I believe because I am looping through the selected rows and the last feature extent values are getting passed into the fishnet geoprocessing tool. I would like to get the extent of the selected features not just the last selected one.
I am unsure of how to get the extent (the LowerLeft, Upper Right, Xmin....etc) of the selected features.
JoshuaBixby
MVP Esteemed Contributor
If you were using ArcMap, then it would be straightforward with Layer.getSelectedExtent().  Unfortunately, for reasons I don't understand, that hasn't been ported to ArcGIS Pro yet.
Although Python reduce has fallen out of favor, I find there are times where it is the most straightforward solution, like in this case.
import arcpy
from functools import reduce
fc = # path to feature class, or layer name if run within Pro
sql = # SQL WHERE clause to select records
with arcpy.da.SearchCursor(fc, "SHAPE@", sql) as cur:
    fullExtent = reduce(arcpy.Geometry.union, (shp for shp, in cur)).extent
Jack_Zhang
Thanks for the solution. I agree found it's very inconvenient to lose some of the basic functions in arcpy.mapping module , which makes it unnecessarily difficult to deal with the layer-type result returned by the Toolbox arcpy functions.
DavidPike
Ah I've gotcha. I'm unsure if features in a FC have an extent object.
You could turn your FC into a feature layer then export each feature as it's own FC then grab the extents that way? Do everything in memory.
Thanks for the help! I was able to use the code provided by David and add to is so I could get the results I needed. It isn't the most straight forward way but it works! Thanks again.
