I'm an ArcPy neophyte/beginner - and this might be a stupid question, but I simply want to return a list of all the contents in a .gdb. When I run the arcpy,listdatasets("*","Feature") function, it appears to work (no errors reported), but I do not 'see' anything. I used it with the 'print' function as well (using the example code provided in the help - copied below) - but I still don't see anything. Where does it go? I only need to see it print to screen so I can copy/paste it....
B.
import arcpy arcpy.env.workspace = "c:/data"
# Print to the Interactive window all the feature datasets in the
# workspace that start with the letter
datasets = arcpy.ListDatasets("C*", "Feature")
for dataset in datasets:
print(dataset)
