arcpy.da.instercursor adding blank rows.
1872
09-07-2018 09:05 AM
Lim_Shane
I am trying to copy a table from an oracle server to a filegdb table.  I can get the searchcursor to work and I can get the insercursor to add all the rows but the field values are all blank.  Any ideas?
arcpy.CreateTable_management(targetPath,targetTableName,SourceTableFullPath,"#")
field_names = [f.name for f in arcpy.ListFields(SourceTableFullPath)]
edit = arcpy.da.Editor(targetPath)
edit.startEditing(False,True)
edit.startOperation()
cursor = arcpy.da.InsertCursor(TargetTablefullPath,field_names)
i = 0
for row in arcpy.da.SearchCursor(SourceTableFullPath, field_names, sourceFilterString):
   i = i + 1
   print row[0] + " " + row[1]
   cursor.insertRow(row)
   if i > 10:
   print i
   break
print "added rows?"
edit.stopOperation()
edit.stopEditing(True)
del row
del cursor
DarrenWiens2
Since you're starting and immediately stopping an edit session, you may as well remove all that and see if it helps.
Lim_Shane
I didn't have any of that in to begin with.  I just started at creating the cursor but I still have the same problem.  I also tried doing it to a personal GDB.  All I can think of is that the new table gets an objectid field and somehow that is messing with the field count but even when I only call out two fields manually they still go in blank.
Lim_Shane
I ended up creating a second copy of the table to insert into.  The first table is somehow read only.
outTbl = str(arcpy.CreateTable_management(targetPath,targetTableName,SourceTableFullPath,"#").getOutput(0))
outTable2 = str(arcpy.TableToTable_conversion(outTbl,targetPath, targetTableName2 ).getOutput(0))
