arcpy.Clip_management -> Error: Floating point division by zero.
3396
09-02-2014 03:14 AM
MarcGoetzke
i am using the arcpy.Clip_management tool with python and i always get the error: Floating point division by zero. In the past it worked. Has somebody an idea?
i have one raster map: test (folder)
and one clipping file: schab.shp
my Python code:
import arcpy
def main():
    arcpy.env.workspace = r'F:/2007/test_rastered'
    arcpy.Clip_management('test', "#", 'F:/2007/test_clipped/test', 'F:/Schablone/schab.shp' , "0", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
if __name__ == '__main__':
    main()
MarcGoetzke
I have checked the projections in ArcMap of the raster and the .shp and they are both correct, they have the same projection. Do not know where the problem is:(
FilipKrál
Strange..., try setting some more environments settings:
in_raster = r'c:\path\to\the\raster'
arcpy.env.snapRaster = in_raster
arcpy.env.extent = arcpy.Describe(in_raster).extent
Consider also arcpy.env.cellSize and other environment settings listed towards the end of the Tool's help.
Also, I think the tool may fail if the polygon you are trying to clip the raster with is too small (relative to the raster cell size). Does your polygon cover more than just a few cells?
MarcGoetzke
Thx Filip. Good idea but it did not help. I still get the error: Floating point division by zero. My polygon for clipping is not small, it is 1/9 of the size of Germany. I want to clip a state of Germany. In did a new polygon who doesnt overlap but it didnt help.
I get the error since i ran ccleaner. perhaps it deleted important temporary files.
i put these in front of the calculation:
arcpy.env.cellSize= in_raster
arcpy.Clip_management(in_raster, "#", out_raster, shapef, "0", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
MarcGoetzke
the error info:
Exception class: EZeroDivide
Exception message: Floating point division by zero.
Exception address: 00007FFE5C004C5D
