ArcPy Batch Processing
3357
03-17-2023 03:19 PM
kjs21059null
Hi!
So I want to use arcpy to run a composite band function. Essentially I have 450+ tif files in one folder, and each file is a separate band from drone imagery. I want to create a script that takes every 4 bands and outputs a composite image into a new folder. Additionally, it would be helpful to be able to label the bands accordingly. I am not sure how to create a loop that will accomplish this, for I am new to working with arcpy. Thanks!
import arcpy
arcpy.env.workspace = ".\\"
output = "Stacked_bands"
for rasters in folder:
band1 =
band2 =
band3 =
band4 =
arcpy.CompositeBands_management("band1.tif;band2.tif;band3.tif;
band4.tif, "stacked_img.tif")
Tags (1)
by Anonymous User
Not applicable
You could utilize multiprocessing to help speed up process of creating 112+ rasters.
In a separate python script named WorkProcess:
Description: Python script used by multithreading create rasters.
Usage: worker method
# IMPORTS
import arcpy
import os
def comp_band(tifs=None):
    result = {'Task': os.path.basename(tifs["outName"]), 'Error': None}
    try:
        arcpy.CompositeBands_management(tifs['tifPaths'], tifs['outName'])
        return result
    except Exception as ex:
        result['Error'] = ex
        return result
Save that it in the same folder that you save this main script below. Borrowing Madhi_ch parsing script above, which is great- I modified a couple lines to output the generated paths into a list of dictionaries {tifs, output name} and added the multiprocessing code:
import os
import arcpy
import multiprocessing as mp
import WorkerProcess
input_dir = r'C:\blah'  # input tifs are here
output_dir = r'C:\blah\Stacked_bands'  # composed tifs will be saved here
def create_tif_groups():
    files = os.listdir(input_dir)  # reads all files in the folder
    # extracts all files that are tif and keeps the name only (drops extension)
    tif_file_names = [i.split('.')[0] for i in files if i.lower().endswith('tif')]
    tifGroups = []
    relations = dict()  # empty dictionary to save file name relations
    for name in tif_file_names:
        # unique_part is the unique part of the name, and we will extract that and use it
        # as a key to a dictionary that holds related file names
        unique_part = f"{name.split('_')[1]}_{name.split('_')[2]}"  # takes 20230316165710_001,  etc
        if unique_part not in relations.keys():  # if the first time, creates a list and appends first file
            relations[unique_part] = [name]
        else:  # if visited that unique part before just adds other files to the same list
            relations[unique_part].append(name)
    # key is the unique part of the name  e.g. 20230316165710_001
    # val is list of 4 file names
    for key, val in relations.items():
        # check point to make sure all your files have 4 files for the bands
        if len(val) == 4:
            pass
        else:
            print(f'There are only {len(val)} files for {key}')  # you can also raise error and stop
        # place holder variables outside of for loop scope
        band_1 = None
        band_2 = None
        band_3 = None
        band_4 = None
        for file_name in val:
            # I am not sure if the orders are important here
            # # but just in case I manually assigned those
            if file_name.endswith('_G'):
                band_1 = os.path.join(input_dir, f'{file_name}.tif')
            elif file_name.endswith('_NIR'):
                band_2 = os.path.join(input_dir, f'{file_name}.tif')
            elif file_name.endswith('_R'):
                band_3 = os.path.join(input_dir, f'{file_name}.tif')
            elif file_name.endswith('_RE'):
                band_4 = os.path.join(input_dir, f'{file_name}.tif')
            else:
                print('Error! Should not land here!')
        # create list of bands and its output path
        tifGroups.append({'tifPaths': [band_1, band_2, band_3, band_4], 'outName': os.path.join(output_dir, f'DJI_{key}.tif')})
    return tifGroups
def mp_tifs():
    # get the list of tif groups and output name from create_tif_groups
    tif_groups = create_tif_groups()
    # set up multiprocessing, leaving one core free to do other tasks. Remove the - 1 to just let it rip on all cores
    cores = mp.cpu_count() - 1
    with mp.Pool(processes=cores) as pool:
        jobs = []
        for batchGroup in tif_groups:
            # Create a job for each tif group and pass it to the worker function.
            jobs.append(pool.apply_async(WorkerProcess.comp_band, (batchGroup,)))
        # get results from the workers
        res = [j.get() for j in jobs]
    # check your results
    for r in res:
        if r['Error'] != None:
            print(f'failed for {r["Error"]}')
if __name__ == '__main__':
    mp_tifs()
Mahdi_Ch
I never worked with tif images in arcpy , but generally if I want to handle the files I will do something like this.
I was not sure if the order of the bands really matter here, but just in case I tried to force the order you had in the screenshot.
Also, I was not sure if you wanted to move each new image into a new folder or all the new ones into one new folder.
import os
import arcpy
# if folder exists pass otherwise create folder to save tifs
if os.path.exists(output_dir):
    pass
else:
    os.makedirs(output_dir)
    if len(val) == 4:
        pass
    else:
        else:
    input_path = f"{band_1};{band_2};{band_3};{band_4}"
    output_path = os.path.join(output_dir, f'DJI_{key}.tif')
    arcpy.CompositeBands_management(input_path, output_path)
 Assuming the Compositeband_manegment() works they way you showed, it should -hopefully- work.
by Anonymous User
Not applicable
# IMPORTS
import arcpy
import os
    try:
        return result
        return result
import os
import arcpy
    tifGroups = []
        if len(val) == 4:
            pass
        else:
        band_1 = None
        band_2 = None
        band_3 = None
        band_4 = None
            else:
    return tifGroups
def mp_tifs():
        jobs = []
    for r in res:
    mp_tifs()
Mahdi_Ch
@Anonymous User
Beautiful! Thank you. Didn't know about the multiprocessing handling in Arcpy.
By the way, I just realized the part that I assigned the path for bands are kind of redundant and could be defined once before assignment as follows:
    # define the path once here and use it below
    file_path = os.path.join(input_dir, f'{file_name}.tif')
        band_1 = file_path
        band_2 = file_path
        band_3 = file_path
        band_4 = file_path
    else: # added the file name as well to be easier to track possible issues
        print(f'Error! Should not land here!- {file_name}')
kjs21059null
Thanks I really appreciate your response! I did get the code to run, and my output was generated how I intended! Thanks again!!
