ArcMap data-driven Python PNG output error
1501
02-06-2023 06:50 AM
Bee99
In ArcMap 10.8.2, I was using data driven with ArcPy,
 All of a sudden, PNG stopped outputting.
 In normal output, it comes out, but when I use Python, it's gone.
 The reason why the image does not appear is because of the output size of the printer, so I tried changing the size, but it does not work.
I tried to fix it with the program installer, but it didn't work.
Even ESRI seems to have a policy to migrate to ArcGISpro, but there are still some things that are not supported. I'm in trouble.
how to do?
Bee99
Thank you for your reply!
I try, try, again.
But, it wasn't caused by python code.
It was due to inserted object format.
I can output the datadrivenpages, with Not PNG, but EMF.
by Anonymous User
Not applicable
Could you share the code that you are using? Are you targeting python 2.7 (ArcMap) or 3 (Pro) for this when its not outputting?
Bee99
I try, try, again.
