ArcGIS World Geocoding Service Request URL
10158
12-10-2021 09:19 AM
JaredPilbeam2
Hello,
I'm using example 4 of this help page to go off of: https://pro.arcgis.com/en/pro-app/latest/tool-reference/geocoding/geocode-addresses.htm#
Excuse my ignorance, but I'm not sure what the full URL should be to access the ArcGIS World Geocoding Service. I'm guessing this is just a base URL in the example, so I'm looking for some direction as to what a complete URL would like?
#ArcGIS World Geocoding Service URL
locator = r"https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/ArcGIS World Geocoding Service"
#Locator parameters
fieldMap = ("\'Address or Place\' adcal VISIBLE NONE;Address2 <None> VISIBLE NONE;Address3 <None> VISIBLE NONE;" +
                  "Neighborhood <None> VISIBLE NONE;City city VISIBLE NONE;County <None> VISIBLE NONE;" +
                  "State state VISIBLE NONE;ZIP ZIP zip VISIBLE NONE;ZIP4 <None> VISIBLE NONE;" +
                  "Country <None> VISIBLE NONE")
gcName = "wasteRecyclingReport_geocode"
geocodeResult = os.path.join(out_location, gcName)
arcpy.geocoding.GeocodeAddresses(intable, locator, fieldMap, geocodeResult)
If you run that you get:
ExecuteError                              Traceback (most recent call last)
~\AppData\Local\Temp/ipykernel_15300/42733642.py in <module>
      7 gcName = "wasteRecyclingReport_geocode"
      8 geocodeResult = os.path.join(out_location, gcName)
----> 9 arcpy.geocoding.GeocodeAddresses(intable, locator, fieldMap, geocodeResult)
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geocoding.py in GeocodeAddresses(in_table, address_locator, in_address_fields, out_feature_class, out_relationship_type, country, location_type, category, output_fields)
    517         return retval
    518     except Exception as e:
--> 519         raise e
    520
    521 @gptooldoc('PackageLocator_geocoding', None)
    514     from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
    515     try:
--> 516         retval = convertArcObjectToPythonObject(gp.GeocodeAddresses_geocoding(*gp_fixargs((in_table, address_locator, in_address_fields, out_feature_class, out_relationship_type, country, location_type, category, output_fields), True)))
    517         return retval
C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py in <lambda>(*args)
    510         val = getattr(self._gp, attr)
    511         if callable(val):
--> 512             return lambda *args: val(*gp_fixargs(args, True))
    513         else:
    514             return convertArcObjectToPythonObject(val)
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000005: Could not open the address locator.
Failed to execute (GeocodeAddresses).
ABishop
Hello Jared,
I did some research on this because I was also curious why you couldn't access the world geocode service and looks like they now require you to create a token and authenticate using your AGOL account.  This is because it is a service provided by ESRI based on credit usage.  See link below.
https://developers.arcgis.com/rest/geocode/api-reference/geocoding-authenticate-a-request.htm
Amanda Bishop, GISP
JaredPilbeam2
@ABishopThanks, that is an option I have to explore.
I just stumbled onto something that works. Run the Geocode Addresses geoprocessing tool with your parameters. Right click the "completed" green ribbon > Copy Python Command. Then copy this into your script.
This is how it looks after setting the results to variables. Funny, the URL never changed. But the parameters don't look the same as the help page example.
locator = "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/ArcGIS World Geocoding Service"
#Locator parameters
fieldMap = ("'Address or Place' adcal VISIBLE NONE;Address2 <None> VISIBLE NONE;Address3 <None> VISIBLE NONE;Neighborhood <None> VISIBLE NONE;City city VISIBLE NONE;County <None> VISIBLE NONE;State state VISIBLE NONE;ZIP zip VISIBLE NONE;ZIP4 <None> VISIBLE NONE;Country <None> VISIBLE NONE")
in_table = os.path.join(defaultDB, "wasteRecyclingReport")
geocodeResult = os.path.join(defaultDB, gcName)
arcpy.geocoding.GeocodeAddresses(in_table,locator,fieldMap, geocodeResult, "STATIC", None, "ROUTING_LOCATION", None, "ALL")
ShanaBritt
@JaredPilbeam2 Have you tried using the SignIntoPortal function as part of your script so that you are signed into ArcGIS Online? There is a note about it above the code in sample 4 in the Geocode Addresses topic, https://pro.arcgis.com/en/pro-app/latest/tool-reference/geocoding/geocode-addresses.htm#GUID-D92B5478-6B6E-4A79-9ECE-1C24BE984FF1.
JaredPilbeam2
Hi @ShanaBritt ,
Yes, I've seen that too. It was in my script already, actually. I understood that it should be used especially in a stand-alone script outside of Pro.
