aprx.activeView Syntax Error
2676
11-13-2020 07:14 AM
ChrisHolmes
Hello,
Can anybody see why I'd be getting a syntax error here? Totally stumped?
Thanks
Tags (1)
EdwinRoa
in arcpy.AddMessage is missing  ")" at the end
EdwinRoa
ChrisHolmes
Thanks. Missing an end bracket. Funny how you can stare and stare and stare at it and it just doesn't pop out!
RachelGomez
If a syntax error appears, check to make sure that the parentheses are matched up correctly. If one end is missing or lined up incorrectly, then type in the correction and check to make sure that the code can be compiled. Keeping the code as organized as possible also helps.
Regards,
Rachel Gomez
