Add seconds to a datetime in arcpy field calculator
5477
12-16-2015 10:02 PM
IanIrmischer
Hi, I have a date field called date with date times in format 4/1/2016 6:40:00 AM
I have a second field called times that is a double with numbers of seconds.
I would like to use arcpy.CalculateField_management to add the seconds to the time in a new date field called futuretime.
I can do this in the field calculator in VB using:
DateAdd ( "s", [times], [date] )
But I am trying to use a script to run through a bunch of files in a for loop.
I started with
for files in allFC:
     arcpy.CalculateField_management(files, "futuretime",?????, "PYTHON_9.3",????)
but I can not figure out the code to fill into the ?????s
Thanks for any help,
Ian
JonMorris2
You can use timedelta to add the two attributes together. For example,
arcpy.CalculateField_management(files, "futuretime", "datetime.datetime.strptime(!date!,'%d/%m/%Y %H:%M:%S') + datetime.timedelta(seconds=!seconds!)", "PYTHON_9.3")
You may want to check the datetime module to make sure I've got the format right.
JonMorris2
IanIrmischer
Jon, Thanks so much.  It worked perfectly.  Really appreciate the help.
Ian
