I prefer the custom toolboxes since you can screen grab the tool properties dialog. Gathering the text information is a bit of a drag, so I have included the script that allows you to do this easily and/or incorporate it into your own toolboxes.
Start with a toolbox, its toolset(s) and tools.
Here is a tool with its input parameter. This one is to document *.atbx toolboxes.
The results of the tool are sent to the messages which can be copies to the clipboard and pasted in your text processor etcetera.
Here is the sample output in a text processor.
Now in custom toolboxes, you fill in the parameters in a dialog. You can follow the various options below
Here is a sample tool.
The general parameters are shown below.
Code executation can be embedded or stored in a location relative to the toolbox itself. That can be in the same folder or in another folder relative to the toolbox.
You can provide validation within the dialog, making it easier to keep your code less cluttered or if your validation is simple or non-existent.
Similarly, you can specify an environment variables within the dialog.
Now if I run the atbx info tool, you get the following results.
atbx info
Tool Path
C:\arcpro_npg\arcpro_36\npg_36\npg_36.atbx\atbxInfo
Parameters
toolbox path C:\arcpro_npg\arcpro_36\npg_36\npg_36.atbx
Messages
Start Time: June 16, 2026 9:00:03 PM
Running ... C:\arcpro_npg\arcpro_36\scripts_npg_36\atbx_info.py
Toolbox : C:\arcpro_npg\arcpro_36\npg_36\npg_36.atbx
Property Value
alias npg36
--Tool Toolset
FeatureVerticesToPoints Featureclass tools
atbxInfo Toolbox properties
fcToGeo Featureclass tools
fcTonpz NumPy tools
npzTofc NumPy tools
Tools and Properties
--Tool : FeatureVerticesToPoints
--Toolset : Featureclass tools
type : ScriptTool
displayname : feature vertices to points
script_file : C:\arcpro_npg\arcpro_36\scripts_npg_36\feature_vertices_to_points.py
description : Convert poly* features to vertices.
product_code : 100
--Parameters
display name : point type
direction : Input
data type : String
parameter type : Required
enabled : True
category : None
symbology : None
multi-value : False
--Tool : atbxInfo
--Toolset : Toolbox properties
type : ScriptTool
displayname : atbx info
script_file : C:\arcpro_npg\arcpro_36\scripts_npg_36\atbx_info.py
description : acquire toolbox info
product_code : 100
--Parameters
display name : toolbox path
direction : Input
data type : File
enabled : True
category : None
symbology : None
multi-value : False
--Tool : fcToGeo
type : ScriptTool
displayname : featureclass to Geo
script_file : C:\arcpro_npg\arcpro_36\scripts_npg_36\featureclass_to_Geo.py
description : Convert a featureclass to a Geo array.
product_code : 100
--Parameters
display name : input features
direction : Input
data type : Feature Layer
enabled : True
category : None
symbology : None
multi-value : False
--Tool : fcTonpz
--Toolset : NumPy tools
type : ScriptTool
displayname : featureclass to npz
script_file : C:\arcpro_npg\arcpro_36\scripts_npg_36\featureclass_to_npz.py
description : Convert a featureclass to a numpy *.npz file.
product_code : 100
--Parameters
display name : npz filename
direction : Input
data type : String
enabled : True
category : None
symbology : None
multi-value : False
--Tool : npzTofc
type : ScriptTool
displayname : npz to featureclass
script_file : C:\arcpro_npg\arcpro_36\scripts_npg_36\npz_to_featureclass.py
description : Convert a numpy *.npz file to a featureclass.
product_code : 100
--Parameters
display name : output featureclass
direction : Output
data type : Feature Class
enabled : True
category : None
symbology : None
multi-value : False
Succeeded at June 16, 2026 9:00:04 PM (Elapsed Time: 0.68 seconds)
Here is the code
# -*- coding: utf-8 -*-
@author: dan_patterson
import sys
import arcpy
from arcgisscripting._arcgisscripting import _utbx
pth_ = arcpy.GetParameterAsText(0) # the path to the toolbox
script = sys.argv[0] # print this should you need to locate the script
def toolbox_info(t_box):
"""Return toolbox information.
Parameters
t_box : toolbox in *.atbx format
Example
t_box = "C:/temp/npGeom_32.atbx"
def _hdr_(hdr_n):
"""Format the header."""
return "{{:<{}s}}".format(hdr_n) + " {!s:<}"
t_box = t_box.replace("\\", "/")
t_props = _utbx.getToolboxProps(t_box, "*")
t_keys = sorted(list(t_props.keys()))
hdr_n = max([len(i) for i in t_keys])
frmt0 = _hdr_(hdr_n)
msg = frmt0.format("Property", "Value") + "\n" + ("-")*(hdr_n + 7)
z0 = ['name', 'display name', 'direction', 'data type', 'parameter type',
'enabled', 'category', 'symbology', 'multi-value']
keys0 = [i for i in t_keys if i != 'tools']
keys1 = 'tools' if 'tools' in t_keys else None
for k in keys0: # toolbox properties
v = t_props[k]
msg += "\n" + frmt0.format(k, v)
if keys1: # `tool` properties
v = t_props[keys1]
v_keys = sorted(list(v.keys()))
hdr_1 = max([len(i) for i in v_keys])
frmt1 = _hdr_(hdr_1)
msg += "\n" + frmt1.format("--Tool", " Toolset")
for k1 in v_keys:
v1 = v[k1]
msg += "\n " + frmt1.format(k1, v1)
for k1 in v_keys:
pth = "{}/{}".format(t_box, k1)
t_0 = _utbx.getToolProps(pth, '*')
tool_keys = list(t_0.keys())
msg += "\n\nTools and Properties"
msg += "\n--Tool : {!s:<}\n--Toolset : {!s:}\n".format(k1, v[k1])
for k2 in tool_keys:
if k2 != 'params':
msg += " {!s:} : {!s}\n".format(k2, t_0[k2])
elif k2 == 'params':
for i in t_0['params']:
z1 = [str(j) if j != '' else 'None'
for j in [i.name, i.displayName, i.direction,
i.datatype, i.parameterType, i.enabled,
i.category, i.symbology, i.multiValue]
msg += "--Parameters\n"
txt = "\n".join([" {!s:<} : {!s:}".format(*j)
for j in list(zip(z0, z1))])
# msg += "parameter"
msg += txt
else:
msg += "unknown"
return msg
msg = toolbox_info(pth_) # -- run
out_ = "\n--------\nRunning ... {}\n--------\n".format(script)
out_ += "\n----\nToolbox : {}\n----\n".format(pth_)
arcpy.AddMessage(out_)
arcpy.AddMessage(msg)
# __main__ .... code section
if __name__ == "__main__":
# print the script source name.
print('\n{} in source script... {}'.format(__name__, script))
# parameters here
So between screen grabs and the atbx info tool, your documentation is complete.
