Format lists and arrays
3779
09-01-2016 07:08 AM
DanPatterson_Retired
1 3 3,779
I have been working with arrays and lists a lot lately and I wanted to view them in column mode rather than in row mode to make documentation easier to follow and to make the output more intuitative.  The demo relies on the numpy module, but that is no issue since everyone has it with their ArcMap and ArcGIS Pro installation.
You can alter where an array gets parsed by changing the values in this line...
np.set_printoptions(edgeitems=2,linewidth=80,precision=2,suppress=True,threshold=8)
I altered the [ and ] characters common in lists and arrays, just to show you could do it.  I also added an indentation option.
If you like the array output better than the list output, you can simply make an array from a list using ... new_array np.array(input_list) ...
Script:    array_print_demo.py
Author:
[email protected]
Modified:  2016-01-16
Purpose:   Demonstration of formatting arrays/lists in alternate formats
Functions:
  -  frmt_arr(arr, indents=0)
  -  indent_arr(arr, indents=1)  called by above
import numpy as np
def frmt_arr(arr, indents=0):
    Format arrays or lists with dimensions >=3 printed by rows rather
    than the usual column expression.  Indentation can be employed as well as
    the number of indent levels.  See string.expandtabs to alter the tab level.
    if isinstance(arr, list):
        arr = np.asarray(arr)  # make sure inputs are array
    result=[]; temp = []
    arr_dim = arr.ndim
    if arr_dim < 3:
        if (arr_dim == 1) and (len(arr[0]) > 1):
            arr = arr.reshape((arr.shape[-1],1))
        if indents:
            arr = indent_arr(arr, indents)
        return arr
    elif arr_dim == 3:
        temp.append(arr)
    elif arr_dim > 3:
        temp = [sub for sub in arr]
    for arr in temp:
        for x in zip(*arr):
            result.append("   ".join(map(str,x))) # use tabs \t, not space
        if arr_dim > 3:
            result.append("----")
        out = "\n".join(result)
    if indents:
        out = indent_arr(out, indents)
        #out = (str(out).replace("[","|")).replace("]","|")
        #tabs = "    "*indents # "\t"
        # out = tabs + out.replace("\n","\n" + tabs)
    return out
def indent_arr(arr, indents=1):
    Add an indent to a str or repr version of an array.
    The number of indents is determined by the indents option.
    out = (str(arr).replace("[","|")).replace("]","|")
    return out
if __name__=='__main__':
    """largely a demonstration of slicing by array dimensions
    # syntax  frmt_arr(arr, indents=1)
    a = np.random.randint(1,1000,16)
    a1 = a.tolist()
    e = a.reshape((4,2,2)); e1 = d.tolist()
Your preference
>>> print(a1)
[[135, 944], [196, 335], [761, 521], [529, 687], [803, 393], [254, 797], [610, 605], [328, 516]]
>>> # or ...
>>> print(frmt_arr(a1,indents=1))
    ||135 944|
     |196 335|
     |610 605|
     |328 516||
A 3D list or array
>>> print(e)
[[[135 944]
  [196 335]]
 [[761 521]
  [529 687]]
 [[803 393]
  [254 797]]
 [[610 605]
  [328 516]]]
>>> # or ...
>>> print(frmt_arr(e,indents =2))
        |135 944|   |761 521|   |803 393|   |610 605|
        |196 335|   |529 687|   |254 797|   |328 516|
3 Comments
XanderBakker
Esri Esteemed Contributor
Cool! Thanx for sharing Dan!
JamesCrandall
pandas version:
import numpy
from pandas import *
a1 = [[135, 944], [196, 335], [761, 521], [529, 687], [803, 393], [254, 797], [610, 605], [328, 516]]
df = pandas.DataFrame(a1)
print df.values
result:
[[135 944]
[196 335]
[761 521]
[529 687]
[803 393]
[254 797]
[610 605]
[328 516]]
but is lines 23 and 24 that are the cool lines
About the Author
Retired Geomatics Instructor at Carleton University. I am a forum MVP and Moderator. Current interests focus on python-based integration in GIS. See... Py... blog, my GeoNet blog...
Labels
